Hi All,
I am looking for any design advice, ideas, for an upcoming project as follows:
There will be 2 6509 switches for core (Collapsed Backbone)
These 2 core switches will connect to 2 more 6509s for use as server distribution switches
The core switches will also connect to 7 4506s in the wiring closet.
The main question I am struggling with is what is the best way to achieve VLAN load balancing & redundancy to the wiring closet, and the server distribution layer (We will have about 20+ VLAN's)?
Secondly, should I connect our firewalls & Mainframe (via OSAs) to the Core or to the server distribution layer? Pros/Cons of one vs the other
I have read numerous Cisco Technical documents including those that pertain to design, but I still feel that I need some detailed feedback from those that have implemented a similar design in a Data Center.
Any help would be very much appreciated.
Pradeep
