Design Issue Multilayer Switched Environment
Does the 4006 Catalyst Switch have any serial line modules to connect WAN connections. I was wondering if it's possible to get rid of our existing 3620 routers if we installed a 4006 for LAN and WAN connectivity? Also, if it is possible to connect serial links to the 4006 is there any data compression solutions?
Same Questions for the 5000 series.
  • Other Network Infrastructure Subjects
Re: Design Issue Multilayer Switched Environment
Cat400x with a Sup1 or Sup2 has the WS-X4604-GWY Module
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat4000/inst_nts/acc_gtwy/index.htm
CAT5000 can support WAN interfaces if you with an RSM and VIP2 http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat5000/hardware/modules/06atm.htm
I see that you also have opened a TAC case. So the TAC Engineer should be able to assist you with this
-Prashanth
The Sup2 4006 does support the AGM module which has serial line capabilities. Currently, the AGM modules is not supported with the Sup3. The AGM may not be a cost effective solution as it is designed for Voice Applications as well.
91
