04-17-2002 04:27 AM - edited 03-01-2019 09:20 PM
I've been asked to design and implement a portion of an ISP's LAN.
The project is about a Housing LAN in which ISP's customers will put their servers.
the simplified schema is the following
|PIX535|-----|CAT 6513|------|CAT 3550|------------------
V V V
L L L
A A A
N N N
Each customer will be given one LAN connection to a departimental cisco 3524 switch, to this connection they can attach one or more server.
Each customer must have its VLAN.
Each customer may agree for a granted bandwith.
Each customer will be assigned an IP range
My questions are :
- I've thought of creating per-port VLAN for each customer , but I don't know how to route packets coming from outiside ( PIX535->CAT6513 ) to the correct VLAN
- Could the creation of per port VLANs pose any problem while implementing QOS ?
TIA
04-17-2002 10:23 PM
Try adding an msfc to the 6500.
04-18-2002 04:26 AM
The 6500 has got the MFSC. How can I set the two switches to have the traffic coming from the 6500 routed to the correct port of the 3500 ?
Each port of the 3500 will belong to a different VLAN but on each of them the hosts are on the same subnet
04-19-2002 09:58 AM
Let me know if this link is of any help;
04-23-2002 01:59 AM
Yes it has been of great help to understand how a possible configuration could be.
Regarding the examples , my situation is similar to the external DMZ . The only difference is that between the PIX and the final switch there's a 6513 .
How can I implement it
TIA
04-26-2002 05:45 AM
How can I implement PVLAN on 3550 ?
04-29-2002 11:42 AM
Here is two links on the edge 3550 switch protected port feature;
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/1218ea1/3550scg/swbcsup.htm
http://www.cisco.com/warp/public/473/63.html
Let me know if this helps.
05-09-2002 09:29 AM
PVLANs are available on the Catalyst 6000 running CatOS 5.4 or later, on the Catalyst 4000, 2980G, 2980G-A, 2948G, and 4912G running CatOS 6.2 or later.
05-09-2002 09:47 AM
Better late than never I guest, check out the link on this page for 3550s.
