Detemining MAC addresses on WS-C2950G switches
On my old WS-C3500XL switches (running IOS ver 12.0(5)WC5(fc1), I could input the following IOS command and figure out the MAC address of hosts that are connected to any switch port interface (int fa0/1 in the example below):
3500xl# show mac int fa0/1
Non-static Address Table:
Destination Address Address Type VLAN Destination Port
0800.20a4.eefe Dynamic 6 FastEthernet0/1
I work in the aerospace industry and this was very useful for me to verify hosts were connected to the correct switch port (especially in remote locations). It also allowed me to verify more easily find out if someone who shouldn't be connected to the net is (i.e. a user that might disconnect a Sun host to put his PC on the net).
On my newer WS-C2950G Catalyst 2950 switches running IOS ver 12.1(22)EA1b(fc1), it no longer supports this same IOS command. Is there another command I can use to get this info?
Scott
3 ACCEPTED SOLUTIONS
Re: Detemining MAC addresses on WS-C2950G switches
Please try 'show mac-address-table interface fa0/12'
HTH and please rate if it does.
Hi Scott,
You can achieve the same with the following command
sh mac-address-table interface
eg
2950#sh mac-address-table interface fa 0/1
0015.2bd7.1821 Dynamic 25 FastEthernet0/1
Narayan
Hi Scott,
You can try
show mac address-table interface
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12120ea2/2950cr/cli2.htm#wp1024589
Ankur
Hi Scott,
eg
Narayan
Hi Scott,
You can try
Ankur
126
