Device fault maanger and uncertified ...
Hello eXperts !
I have a small problem. When I launch the administartion console, I see all my cisco switch in the uncertified tree and I don't know why ?
Does i need to apply an update and if so, which one ?
Thanks for your help
Guillaume
1 REPLY
Blue
Re: Device fault maanger and uncertified ...
What is the device model and the version of DFM?. Assuming that it is DFM 1.2, refer to the Supported Device List to verify if your device is listed as supported or it is supported by the latest DFM 1.2 IDU:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/dfm/dev_sup/dfm1_2.htm
92
