DFM and Catalyst 4006
DFM 1.1 does not see the 3rd power supply in my 4006 switches.
Any ideas on how to get DFM to see them.
When the 3rd PS goes down. DFM never sees a trap nor does my NMS.
Blue
Re: DFM and Catalyst 4006
Under the DFM Administration Console, do you see all three power supplies listed for this particular 4K switch, when you goto Switch->This 4006 switch->ComposedOf->PowerSupply ?
No.
>ComposedOf>PowerSupply 1 and PowerSupply 2 no PowerSupply 3 listing.
Blue
If DFM is not listing/showing the 3rd power supply there, it cannot do any fault management for that particular element either. Try deleting this particulat switch from the DFM Administration Console and then re-add it back again manually using Add Agent option and see if it shows the 3rd power supply or not. As a side note, if you have not installed DFM 1.1 IDS 1.1.2 patch from CCO, you may want to install that as well.
262
