DFM and RTM on the same machine
When installing RTM and DFM on the same machine the trap port conflicts.
An alternative port for RTM would be 395 (just like TrafficDirector in the past)
However, should I change the device config aswell?
e.g. by setting up a command like snmp-server source-port (I know you can change 162, the default in some IOS) or is this handled internally by the applications?
My other question, in which configuration file in respectively RTM and DFM this port number can be changed?
Thanks in advance for any help!
1 REPLY
Blue
Re: DFM and RTM on the same machine
See the details of CSCdt62297 via CCO Bug Toolkit for the workaround.
81
