Webcast-Catalyst9k
Bronze
DFM: Matching Criteria problem
I'm battling to add a new group in the Thresholds tab in DFM.
I want to put all my 3640's in one group and to set their serial interface utilisation thresholds different to the default. So from the matiching criteria I choose the "SystemModel" element and set the value to 3640. Then , as instructed, I do a Reconfigure and then a "Save Inventory" . DFM reports two 3640's from its initial discovery , yet in my Thresholds tab I do not see any members in my newly created group. Surely once I see those two in "members" that would be my verification that they are being managed.
What am doing wrong here ?
1 ACCEPTED SOLUTION
Re: DFM: Matching Criteria problem
Make sure you've setup your customer group to a higher priority then in this case the group routers. Otherwise the 3640 matches this group. It's a top/down process. First match wins.
Bronze
Man, you were right on the money. I played with it for looong while and stumbled upon the crucial configuration setting. Since that priotization it works now. Many thanks.
196
