Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DFM port filter problem
How the DFM put the switch ports (e.g. the 10/100 ports) into the different groups:
- Interface Groups//10/100Mb Ethernet
- Port Groups – Access Ports//10/100Mb Ethernet
- Port Groups – Trunk Ports//10/100Mb Ethernet
if in each 10/100Mb Ethernet group the matching criteria is the following:
- Type: *ETHER*|*CSMACD*
and there is no priority between the different groups.
I’m asking that because I found all the 10/100Mb ports in the Port Groups – Trunk Ports//10/100Mb Ethernet independently whether is this a trunk or not. There are ports where the PortType is ACCESS and they are also in the Port Groups – Trunk Ports//10/100Mb Ethernet group.
I’m using DFM 1.2 and IDU 1.2 as well as 2950-12T and 3550 switches.
1 REPLY
Re: DFM port filter problem
This document below answers some of the very frequently asked questions on DFM. I am sure you will find some useful stuff here.
http://www.cisco.com/en/US/products/sw/cscowork/ps2421/prod_troubleshooting_guide09186a00800b1209.html
108
