DFM problem - PPP and ONDEMAND mode
Hi there,
We're running DFM 1.2.4 with CW2000 (Windows) and we're having a problem with serial interfaces. We have a number of routers interconnected via T-1's running PPP. However, DFM on discovery sets these interfaces to "ONDEMAND" mode, which in turn generates a number of "Exceeded Maximum Uptime" faults. I've set the interfaces to "NORMAL" mode, applied the changes, done a "Reconfigure" and a "Save Inventory". However, the mode value seems to change back to "ONDEMAND" mode after the next discovery or poll. Obviously PPP exists outside the Dial-On-Demand arena; how can I convince DFM of that?
Brian Read
Blue
Re: DFM problem - PPP and ONDEMAND mode
CSCdu28633 with the following workaround:
DFM marks serial interface with encapsulation PPP as On Demand Interface. It will give "Exceeded Maximum Uptime" message in the Alarms.
Marking the interfaces as On Demand is according to design. To change the mode to NORMAL, do the following in the Polling and Thresholds Console, under Interface Groups:
1) Create a new Interface Group called "PPP interface"
2) Add the following Matching Criteria
Type = *PPP*
3) Increase the Priority of this new PPP interface Group to a higher
level than the default group Dial on Demand.
4) Reconfigure.
5) Verify that there are now members under the PPP Interface Group.
See if this helps.
Hey, I think that did it. Thanks for the tip.
BR
128
