12-04-2002 11:01 AM - edited 03-02-2019 03:22 AM
On Solaris , CW 2001 LMS(NNM on the same server) DFM Trap Notifier dosn't
work when CW comes up.
It start forwarding just after a disable/enable.
Does anyone has figth agani this?
12-04-2002 11:10 AM
What is the version of DFM and have you installed any DFM IDU patch from CCO?. From your description it looks like you're forwarding traps from DFM to HPOV?. If this is the case then the latest DFM 1.2 IDU patch should fix this issue.
12-04-2002 11:20 AM
DFM 1.2
Can you suggest how to reach the patch on www.cisco.com
and
the smarter way to be aligned with software patches distributions ?
12-04-2002 11:31 AM
You can get the latest DFM 1.2 IDU 1.2.3 patch from: http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-dfm
Refer to the Readme file for install procedure and other details.
12-05-2002 06:16 AM
thank
I'm gonna test when our test bed'll be ready...don't ask...is better
thanks again
bye
12-05-2002 06:22 AM
thank
thanks again
bye
