Community Member
DHCP and Configuring Manual Bindings on a 827
Greetings,
I am currently trying to configure manual bindings on a router using DHCP. Configuring DHCP is relatively easy and painless, but how do you get the DHCP server on the router to statically assign an IP based on MAC address? I located some docs that mentioned using manual bindings, but the router appears to ignore the binding and assign any IP address in the Network pool. Can anyone tell me where I have gone wrong?
ip dhcp excluded-address 192.168.0.1 192.168.0.30
ip dhcp pool test1
host 192.168.0.55 255.255.255.0
hardware-address 0100.07e9.b9a9.51
default-router 192.168.0.1
dns-server 139.130.4.4
ip dhcp pool LAN
network 192.168.0.1 255.255.255.0
domain-name test.com
dns-server 139.130.4.4 203.9.249.201
netbios-name-server 192.168.0.20
lease 1 0 10
1 REPLY
Community Member
Re: DHCP and Configuring Manual Bindings on a 827
The hardware-address you have is not vaild. The command hardware-address do does not need 01 as does client-identifier. Try chaning the line to hardware-address 0007.e9b9.a951
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/ip_r/iprprt1/1rddhcp.htm#1017792
103
