11-04-2003 03:09 PM - edited 03-02-2019 11:28 AM
Hello
I have to 4507R's that are etherchanneled together and have the floowing VLANS on each
VLAN 2 - 10.104.0.0/23
VLAN 3 - 10.103.0.0/23
VLAN 4 - Voice - 10.110.0.0/23
VLAN 5 - Connected to 2691 10.0.255.0/23
VLAN 411 - Management - 10.110.2.0/23
Each also has the AGM -WS-X4604-GWY module in it and 1 48-port 10/100 module
I configured
interface GigabitEthernet6/1
switchport trunk native vlan 411
switchport mode trunk
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.103.0.2 255.255.254.0
no ip redirects
standby 2 ip 10.103.0.1
standby 2 priority 110
standby 2 preempt
interface Vlan3
ip address 10.104.0.2 255.255.254.0
no ip redirects
standby 3 ip 10.104.0.1
standby 3 preempt
interface Vlan4
ip address 10.110.0.18 255.255.254.0
no ip redirects
standby 4 ip 10.110.0.1
standby 4 priority 110
standby 4 preempt
interface Vlan411
ip address 10.110.2.2 255.255.255.0
standby 255 ip 10.110.2.1
standby 255 priority 100
standby 255 preempt
GW-1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
arp timeout 600
interface GigabitEthernet0/0
ip address 10.110.2.4 255.255.254.0
no negotiation auto
standby 255 preempt
AGM is in GW mode but using external 2691 router to get back to main site
1. If I do not configure subinterfaces on the Gig interface I cannot get back to CCM or any other VLAN
2. If i configure th interface like this then I never get an IP address in the VLAN that it is supposed to pull from it pulls from the VOICE DHCP
interface FastEthernet5/7
switchport trunk native vlan 2
switchport voice vlan 4
spanning-tree portfast
I am running the 12.2(13)EW image.
Can any help out on this and can someone with a great knowledge of 4507R's, spanning-tree, and a few more other questions talk to me sometime to see if I am doing this the proper way.
Thanks for your assistance.
Brian bhenry33@adelphia.net
Solved! Go to Solution.
11-06-2003 06:57 PM
I believe that you had a TAC case open as well and i was helping out the case owner on this one. The call manager/DHCP server port needs to be an Access vLAN. We changed the port to access VLAN 4 and had you reboot the Call manager to purge the DHCP cache. Rebooting alone would not have fixed this issue.
11-05-2003 06:31 PM
Hi Brian,
I am not familiar with most of the stuff you are running, but I may have a tip on the dhcp ip address issue. On each router interface (vlan) you need to configure an "ip helper" address that points to a dhcp server, so the router can redirect dhcp discovers to the correct server - unless the dhcp server exists in the same vlan as the dhcp client.
Hope this helps,
Jeremy
11-05-2003 06:56 PM
Thanks for the response but I did have the IP-helper address in the VLAN's but it made no difference, for which they were in there all day today when I was trying to get it to work and even with Csico on the phone Tier 1 support.
If you have any other recommndations I am all ears and thanks again for the response
11-06-2003 12:44 PM
I think you need to have a ip helper-address command under each vlan interface
interface Vlan3
ip helper-address IP_address_of_DHCP_server
no ip redirects
standby 3 preempt
11-06-2003 06:49 PM
The configs that were posted wer a little miss leading trying to type what was in the configs and missed a few lines, but the IP helper was in there but made no difference of pointing to the server dirreclty or using the broadcast addresss for the subnet that it sat on.
The fix is below
Thanks to all but it has been fixed by, you won't believe it, a reboot of the DHCP server which the service sits on the publisher CCM.
Who says that a reboot isn't good every once in awhile.
Thanks to all that responded!
11-06-2003 06:57 PM
11-07-2003 02:08 AM
Sorry for the miss information but I thought that is was already an access VLAN, my bust. I do believe that the final config for that port for which the CCM/DHCP sat on looks like this.
If all it needs to have is the access command and the spanning-tree I will remove this am when I get in.
switchport access vlan 4
switchport trunk encapsulation dit1q
spanning-tree guard root
Thanks for corecting me, trying to remember everything we tried and did after going out and having a few didn't mix.
Thanks again for everyones help!
B
