DHCP and WEP in WLAN
350 AP and NIC. When not using WEP profile I get DHCP assigned addressing and DNS info. When I activate WEP profile I authenticate, but I do not receive DHCP info. IPCONFIG /RENEW responds with DHCP Server unreachable. I have the latest drivers and ACU. Any thoughts?
Re: DHCP and WEP in WLAN
I'm assuming that when you say you authenticate, you mean you associate, which you would do whether or not your WEP keys are correct. If you manually assign an address to your system, can you ping anything? It probably sounds redundant, but please re-enter your WEP keys on both the client and AP to make sure they are exactly the same. If that doesn't work, please supply the exact parameters in your ACU configuration.
Definitely had this type of configuration working, but not without having to re-enter the WEP configuration a few times - probably stating the obvious, but maybe try a static IP 1st to confirm WEP auth is working, and then move to DHCP.
Good luck,
Matt
80
