DHCP HELP Please.......
I have all DHCP clients and server on same VLAN in the same subnet on CAT4507.
I can also ping DHCP server, but the clients are not getting IPs. I've checked DHCP config on server seems to be OK. When I turn on debug I get following:
1w3d:
-----Additional Debug------
1w3d: DHCP process ID FFFFFFFF status 0
1w3d: DHCP Network Discovery is disabled
1w3d: DHCP NetDiscovery Informs 0 Discovers 0 Period 0
1 ACCEPTED SOLUTION
Re: DHCP HELP Please.......
can you make sure that "spanning-tree portfast" is enabled on the client port and server port? Can you also post the client and server port config, if possible?
I don't have spanning-tree port-fast enabled. I plugged in all cables into a small switch(i.e. bypassing CISCO) and worked fine!! So, I need to set something up in CISCO but what? Do I have enable DHCP somehow?
This is what I have:
interface FastEthernet3/1
switchport access vlan 21
interface FastEthernet3/2
interface FastEthernet3/3
interface Vlan21
description VLAN21-SIGTRAN-EXCEL
ip address 10.18.89.126 255.255.255.192
Enabling portfast worked!!! But why?
Thanks for your help
without portfast the port goes through the usual stages of spanning-tree, blocking, learning, forwarding. This stages is enough to cause start-up delay issues with DHCP, windows, Novell, Etc. with portfast the port is put in forwarding mode immediately upon connection.
try putting in "spanning-tree portfast" under the interfaces where the client and server are connected as I earlier suggested.
294
