DHCP on LAN-Segment with secondary IP-Address-Range
Situation:
DHCP-Server (W2K) in VLAN 1 (192.168.168.115/24)
Router between VLAN 1 (192.168.168.1/24) and VLAN 2 (192.168.169.1/24)
Secondary IP-Address-Range in VLAN 2 on Router-Interface (172.0.0.1/24)
Router forwards DHCP-Requests from VLAN 2 to DHCP-Server.
interface Vlan2
ip address 172.0.0.1 255.255.255.0 secondary
ip address 192.168.169.1 255.255.255.0
ip helper-address 192.168.168.115
DHCP-Server receives the packets from Routers Primary address (192.168.169.1) and will give a lease out of that range
Question:
How to configure DHCP-Server / Router to give leases (reservations) out of the secondary range (172.0.0.x) to the clients.
Bronze
Re: DHCP on LAN-Segment with secondary IP-Address-Range
Unfortunately, there is no way to implement DHCP on the secondary address range.
Hi, I think you should implement a superscope in the DHCP server which includes both subnets within the same Vlan2. Then you should make the coresponding reservations and permitted leasings
134
