DHCP problems in VLANs
I have a DHCP server setup in my default VLAN1. I have two other VLANs and I have configured iphelper address for those two vlans
I have no problem in the default vlan. I get the DHCP addresses fast without an issue. The dhcp server is also in default vlan
I have configured the ip helper address only in core switches. do I need to configure them for all individual switches. please let me know.
Re: DHCP problems in VLANs
You need to put the "ip helper-address x.x.x.x" under the Layer 3 interface where the client's default gateway is. for example, client in vlan x needs IP address from the DHCP server in vlan 1. At the layer 3 device, this would be the router or L3 switch doing the L3 or inter-vlan routing,under interface vlax x is where you will put "ip helper-address
Please rate helpful posts.
If your core switches are the default gateway for those users on those two VLANs and that's where you need to configure the 'ip helper-address (dhcp_ip)' command. If you have already done that and still having problems it might be due to spanning tree convergence. Configure
'spanning-tree portfast' on the ports to which users are connected.
Let us know if it helped.
Sundar
I had a similar problem and the only way I could get DHCP to work was to add the "Directed-Broadcasts" command to the vlan interfaces. Hope this helps.
Hall of Fame Super Silver
Is it possible that your helper address configuration gave the address to forward to as a subnet broadcast (something like ip helper-address 172.16.6.255)?
This would require enabling directed broadcast on the interface where the server(s) is located.
Rick
124
