Webcast-Catalyst9k
DHCP problems with 1720
Situation: site A with 2612 (IOS 12.1.5.YB5), server Windows/2000+active directory, DHCP-server. etc.
site B with 1720 (IOS 12.1.5.YB5) connected to site A over ADSL.
PROBLEM: the PC client don't receive IP address from the remote server.
ALL CHECKED: Server, DHCP-service, routing, etc seams to work correctly, but ...
Thank's.
Claudio
Re: DHCP problems with 1720
Try an IP Helper Address.
OBVIOUSLY I use IP Helper-address on the LAN interface (FastEthernet) ...
I used the same configuration I am using for the 26xx's: but with the 26xx's it works very wel.
Looking at IP accounting on the 1720, I see pakets with source 0.0.0.0 and destination , but NO returns pakets.
This may help:
http://www.cisco.com/warp/public/473/100.html
If not, can you post the config of the 1720 or sniff the dhcp to make sure it is replying?
Steve
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname rupe
no logging rate-limit
enable password (...)!
clock timezone italy 1
clock summer-time Italy recurring last Sun Mar 2:00 last Sun Oct 3:00
ip subnet-zero
no ip source-route
no ip finger
no ip domain-lookup
no ip dhcp-client network-discovery
source-bridge ring-group 2000
dlsw local-peer peer-id 10.123.30.6
dlsw remote-peer 0 tcp 10.123.30.110 keepalive 0 timeout 90 dynamic no-llc 1
dlsw icannotreach sap AA E0 F0
dlsw bridge-group 53
interface Loopback0
ip address 10.123.30.6 255.255.255.255
interface ATM0
description Connesso a RETE DSL
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no ip mroute-cache
atm vc-per-vp 256
no atm ilmi-keepalive
dsl operating-mode auto
no fair-queue
hold-queue 208 in
interface ATM0.1 point-to-point
description Connesso a sede
ip address 10.123.31.34 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip nat outside
no ip route-cache
no ip mroute-cache
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
ip address 10.123.6.1 255.255.255.0
ip helper-address 10.123.0.23
no keepalive
speed auto
bridge-group 53
interface Serial0
description "Collegamento verso Bancomat"
no ip address
encapsulation sdlc
no keepalive
nrzi-encoding
clockrate 9600
sdlc role primary
sdlc vmac 4001.2300.6e00
sdlc poll-pause-timer 20
sdlc address B2
sdlc xid B2 05D306B2
sdlc partner 4000.1000.0002 B2
sdlc line-speed 9600
sdlc dlsw B2
router eigrp 52
redistribute static
network 10.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 ATM0.1
no ip http server
access-list 90 permit 10.120.0.15
access-list 90 permit 10.120.0.200
access-list 90 deny any log
access-list 100 deny eigrp any any
access-list 100 deny udp any any eq snmp
access-list 100 deny udp any any eq snmptrap
access-list 100 deny udp any any eq ntp
access-list 100 permit ip any any
access-list 110 permit tcp any eq 2065 any eq 2065
access-list 110 permit tcp 10.120.0.0 0.0.0.255 eq 1477 any
access-list 110 permit tcp 10.120.0.0 0.0.0.255 eq 1478 any
access-list 110 permit tcp any any eq 1477
access-list 110 permit tcp any any eq 1478
access-list 110 permit tcp 10.120.0.32 0.0.0.15 range 22001 25999 any
access-list 110 permit tcp 10.120.31.32 0.0.0.15 range 22001 25999 any
access-list 110 permit tcp any 10.120.0.32 0.0.0.15 range 22001 25999
access-list 110 permit tcp any 10.120.31.32 0.0.0.15 range 22001 25999
access-list 110 permit tcp any any eq telnet
access-list 110 permit tcp any eq telnet any
access-list 110 permit tcp host 10.120.0.24 eq 139 any
access-list 110 permit tcp host 10.120.0.25 eq 139 any
access-list 110 permit tcp host 10.120.0.33 eq 139 any
access-list 110 permit tcp host 10.120.0.34 eq 139 any
access-list 110 permit tcp host 10.120.0.42 eq 139 any
access-list 110 permit tcp host 10.120.0.43 eq 139 any
access-list 110 permit tcp host 10.120.0.51 eq 139 any
access-list 110 permit tcp host 10.120.0.52 eq 139 any
access-list 110 permit tcp any host 10.120.0.24 eq 139
access-list 110 permit tcp any host 10.120.0.25 eq 139
access-list 110 permit tcp any host 10.120.0.33 eq 139
access-list 110 permit tcp any host 10.120.0.34 eq 139
access-list 110 permit tcp any host 10.120.0.42 eq 139
access-list 110 permit tcp any host 10.120.0.43 eq 139
access-list 110 permit tcp any host 10.120.0.51 eq 139
access-list 110 permit tcp any host 10.120.0.52 eq 139
priority-list 1 protocol ip high tcp 2065
priority-list 1 protocol ip high tcp 1477
priority-list 1 protocol ip high tcp 1478
priority-list 1 protocol ip high tcp 1424
priority-list 1 protocol ip high tcp 1414
priority-list 1 protocol ip high tcp telnet
priority-list 1 protocol ip low gt 1024
priority-list 1 protocol ip high list 110
priority-list 1 protocol ip low tcp ftp
priority-list 1 protocol ip low tcp ftp-data
priority-list 1 queue-limit 40 40 20 7
snmp-server community public RO
snmp-server community crtnet RW 90
snmp-server trap-source Loopback0
snmp-server location (...)
bridge 53 protocol ieee
banner login (...)
line con 0
exec-timeout 60 0
transport input none
line aux 0
line vty 0 4
exec-timeout 60 0
password (...)
login
no scheduler max-task-time
no scheduler allocate
ntp clock-period 17180696
ntp server 10.120.31.254
ntp server 10.120.31.253
end
Quick points:
1. Where is the ip nat inside? Cut out of the post?
2. access-list 100 references a dialer-list?
3. acl 90 an access-class?
4. as a side note interesting you are redistributing a default route into eigrp, I thought this was a remote site.
Only things I can think of:
1. put a sniffer on to make sure dhcp is in fact replying
2. nat is messing with the helpered traffic (similiar to bug CSCdj92460).
1) Why do I need to use NAT? When in a "closed" network, without connection to InterNet, I usually don't use NAT
2) Acces-list 100 is NOT used (but YES, it refers to a Dialer-list)
3) ACL 90 is user to filter SNMP WR community
4) Right, I have to correct the mistake
Moreover: actually, I can't put a sniffer; I tried using IP ACCOUNTING, as I wrote inthe first post.
Thank's
118
