DHCP servers plugged in bkwds in our LAN
I work for Cox Communications and we have several apartment complexes in the Bryan region. They are in a standard layer 2 LAN environment with fiber back to our headend using 3550-48's. The problem is, some customers are plugging in their lynksys routers backwards and answering DHCP request from our other customers on the LAN and therefore, they are receiving 192 addy's from this device. I know of dhcp snooping on the 4000's but that isn't available on the 3550 and I can't figure out how to implement ACLs since everything is layer 2. Port security would work, but our GM in Bryan doesn't want to do that because these are college students and transfer files back and forth to each other. Does anyone have any suggestions on what I can do to restrict the ports from answering dhcp broadcast packets?
Bronze
Re: DHCP servers plugged in bkwds in our LAN
I think you can put a Layer3 ACL on a layer 2 port on a 3550 (inbound only):
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12114ea1/3550scg/swacl.htm#75854
UDP port 68=DHCP client
UDP port 67=DHCP server
Maybe an ACL:
access-list 100 deny udp any eq bootps any eq bootpc
access-list 100 permit ip any any
and then access-group 100 in on all your ports except for the one that has your authorized DHCP server would do the trick?
Not sure...never tried it
I will do some testing with our on-site engineer with this tomorrow. It does seem like it should work, I will let you know. Thanks
86
