dhcp settings
dear sir,
I wish to setup dhcp server at switch. Refer to below config, this is the configuration for switch. however i'm not sure of the meaning as below :-
network 165.204.184.0 255.255.255.0(How many ip address it will lease) ?
dns-server 165.204.164.235
option 150 ip 165.204.184.4 (what's the meaning of option 150 ip 165.204.184.4)?
default-router 165.204.184.99 ( it did default-router 165.204.184.99 ) ? What's the meaning?
Please advise.
Below is the sample working config.
thanks.
interface Vlan1
ip address 165.204.184.99 255.255.255.0
end
Switch#sh run | begin dhcp
ip dhcp excluded-address 165.204.184.99 165.204.184.240
ip dhcp excluded-address 165.204.184.1 165.204.184.10
ip dhcp pool DataVLAN
Re: dhcp settings
Hi chialun ,
This switch as a DHCP server it can assign any ip address in 165.204.184.0 network, except the excluded addresses 165.204.184.99 & 165.204.184.1
option 150 used to mention as parameter passed is Data Type is a IP Address to DHCP clinet
default router is a gateway address for the DHCP client.
Madan
Rate me if it solved your issue
Re: dhcp settings
hi madan,
thank you for your reply.
i don't understand the explaination ? very sorry.
83
