Community Member
DHCP snooping setup help
Can anyone help me with these setup issues.
The Cat OS config guide chapter "configuring DHCP-snooping and IP source guard" for v8.4 doesnt mention how to:
1) Disable dhcp-snooping
2) configure a destination for the snooping database.
I would like to setup the local flash PCMCIA card as a destination for the DB.
I have found documentation for other releases of CatOS that state how to specify a DB location:
set dhcp-snooping bindings-database <device>:[filename]
However this syntax is not supported in 8.4. With command line auto-complete (the tab key) and/or help there is no option for "bindings-database" available.
Do I need to activate the DB somewhere else in the config?
thanks,
1 REPLY
Silver
Re: DHCP snooping setup help
The command to disable DHCP snooping is:disabled the ip dhcp snooping
237
