DHCP static IP to Network Printer
Anand Narayana
Level 6
Level 6
Actually my requirement is,i wanted each & every pc & network printers to obtain the IP address from the DHCP server, so when it comes to network printer, the IP address should be static, so i wanted to specify in such a way that one particualr IP should be assigned only for a particular mac-address. so is that possible? also is there any possibility to set a host name also to the pc via dhcp?
spremkumar
Level 9
Level 9
AFAIK u can make use of hardware address option to reserve ip address to the printer based on the mac address of the printer..
hope this link helps u out ..
http://cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca75c.html#wp1017385
regds
spremkumar
Level 9
Level 9
regds
hi prem,
i tried the configuration, but i didn't work out, i mean it is not taking any IP address on my windows 2000 professional. so how do i proceed now? the client hardware address i specified is the mac-address of the windows 2000 pc.
actually when i tried with linux, it really worked, so problem with windows 2000. thankz a lot
I think Martin´s original post was right, but you need to add the client-identifier option as well, as described below. Also, I am not sure if the IEEE option is correct, you might want to try the default, which is Ethernet. So, putting this together, try the config below:
ip dhcp pool Mars
host 172.16.2.254 mask 255.255.255.0
hardware-address 02c7.f800.0422
client-name Mars
--> client-identifier 0102.c7f8.0004.22
default-router 172.16.2.100 172.16.2.101
domain-name cisco.com
dns-server 172.16.1.102 172.16.2.102
netbios-name-server 172.16.1.103 172.16.2.103
netbios-node-type h-node
GP
