Webcast-Catalyst9k
DHCP UDP packet is not forward.
Recently, I configured some security options on my routers.
- disabled Bootp service w/ command "no bootp server"
- disabled redirect w/ command "no ip redirect"
- disabled ip directed-broadcast w/ command "no ip directed-broadcast"
Then, DHCP client could not be assigned IP address.
So, I returned old config. but i don't know yet what command occured ?
Re: DHCP UDP packet is not forward.
DHCP is an extension of BOOTP so i would guess "no bootp server" was the command that did it.
Why do you think so? What function of BOOTP do ? If bootp were enabled, the "ip helper" command is not needed to forward DHCP packets ? I don't think so. I'm confused.
83
