DHCP with manual bindings
I have a Catalyst 3550-12G with the following configuration (DHCP with manual bindings)
interface Vlan50
description Vlan Temporanea
ip address 10.9.50.1 255.255.255.0
ip dhcp excluded-address 10.9.50.1
ip dhcp excluded-address 10.9.50.7 10.9.50.254
ip dhcp pool TEMP3
host 10.9.50.3 255.255.255.0
hardware-address 0002.3f11.d4b2
default-router 10.9.50.1
dns-server 10.191.255.61
domain-name comitato.torino2006.it
DHCP doesn't work and I receive the following log messages:
Oct 27 14:47:22.924: DHCPD: discarding stub packet (128 bytes)
Oct 27 14:47:24.936: DHCPD: discarding stub packet (128 bytes)
Oct 27 14:47:34.656: DHCPD: discarding stub packet (128 bytes)
Oct 27 14:47:39.884: DHCPD: discarding stub packet (128 bytes)
Oct 27 14:47:43.584: DHCPD: DHCPDISCOVER received from client 0100.023f.11d4.b2 on interface Vlan50
Oct 27 14:47:43.584: DHCPD: there is no address pool for 10.9.50.1
Oct 27 14:47:45.692: DHCPD: discarding stub packet (128 bytes)
Oct 27 14:47:46.588: DHCPD: DHCPDISCOVER received from client 0100.023f.11d4.b2 on interface Vlan50
Oct 27 14:47:46.588: DHCPD: there is no address pool for 10.9.50.1
Oct 27 14:47:53.588: DHCPD: DHCPDISCOVER received from client 0100.023f.11d4.b2 on interface Vlan50
Oct 27 14:47:53.588: DHCPD: there is no address pool for 10.9.50.1
Oct 27 14:47:53.812: DHCPD: discarding stub packet (128 bytes)
As you can see from logs below, if I configure DHCP without manual bindings (see configuration below) all is working
ip dhcp pool TEMP
network 10.9.50.0 255.255.255.0
Oct 27 15:16:17.492: DHCPD: discarding stub packet (128 bytes).
Oct 27 15:16:21.104: DHCPD: DHCPDISCOVER received from client 0100.023f.11d4.b2 on interface Vlan50.
Oct 27 15:16:21.104: DHCPD: requested address 169.254.144.125 is not on subnet 10.9.50.0.
Oct 27 15:16:23.104: DHCPD: assigned IP address 10.9.50.2 to client 0100.023f.11d4.b2.
Oct 27 15:16:23.104: DHCPD: Sending DHCPOFFER to client 0100.023f.11d4.b2 (10.9.50.2).
Oct 27 15:16:23.104: DHCPD: child pool: 10.9.50.0 / 255.255.255.0 (TEMP)
Oct 27 15:16:23.104: DHCPD: pool TEMP has no parent.
Oct 27 15:16:23.104: DHCPD: broadcasting BOOTREPLY to client 0002.3f11.d4b2.
Oct 27 15:16:23.104: DHCPD: DHCPREQUEST received from client 0100.023f.11d4.b2.
Oct 27 15:16:23.104: DHCPD: Sending DHCPACK to client 0100.023f.11d4.b2 (10.9.50.2).
Oct 27 15:16:27.212: DHCPD: discarding stub packet (128 bytes).
Why DHCP with manual bindings doesn't work?
Stefano
1 ACCEPTED SOLUTION
Re: DHCP with manual bindings
Hi Stefano,
Config looks to be fine. Can you remove "hardware-address" command and try this
client-identifier 0100.023f.11d4.b2
I hope the clinets are Microsoft Dynamic Host Configuration Protocol (DHCP) client
Give a shot with this command instead of hardware address and update if it works.
Ankur
1 REPLY
Hi Stefano,
Ankur
277
