Community Member
Diagnosing ISDN problem
I have found a document which describes how to troubleshoot ISDN problems with the command:
#debug bri
According to this document, one could determine wether the problem would be internal or external to the router. This should be done by analyzing the values of "Write_sid" (shown as "wrote=x" on most routers) and the SID interrupt status "reg=x".
However none of these values are displayed after typing the "debug bri" command.
Does anybody have experience with this?
Thanks!
1 REPLY
Community Member
Re: Diagnosing ISDN problem
The document what you read is right.
If you run
" debug bri-interface "
" logging on "
then with "terminal monitor on" from the telnet window must show the real time activity of BRI interfaces.
82
