Webcast-Catalyst9k
Dial backup problem
We have upgraded our ios an all 2610 routers to version 12.2(17a). Since then we faced the following problem:
Dialer0 does not triger a call to the main router. To solve the problem, we shutdown the dialer0 interface, save configuration, reload the router and issue the command "no shutdown" at the dialer0 interface. This seems to solve the problem temporarily since when the router is reloaded the same problem exists again and we have to do the same procedure again. Does anybody know how to solve the above problem?
thanks
Re: Dial backup problem
What is your latest config on this router? Can you paste it?
Please find below the configuration. Before the upgrade of the ios we had no problem.
thanks
interface Serial0/0
no ip address
encapsulation frame-relay
no ip mroute-cache
frame-relay traffic-shaping
frame-relay lmi-type q933a
interface Serial0/0.1 point-to-point
bandwidth 128
backup delay 0 180
backup interface Dialer0
ip address 10.0.24.33 255.255.255.252
ip ospf network point-to-point
no ip mroute-cache
frame-relay interface-dlci 20
class CIR_64K
frame-relay ip rtp header-compression
interface BRI0/0
no ip address
encapsulation ppp
no ip mroute-cache
dialer pool-member 1
isdn switch-type basic-net3
interface Serial0/1
no ip address
shutdown
interface Dialer0
ip address 4.4.4.49 255.255.255.0
encapsulation ppp
ip ospf network point-to-multipoint
ip ospf demand-circuit
no ip mroute-cache
dialer pool 1
dialer idle-timeout 300
dialer string 80009019
dialer load-threshold 150 either
dialer-group 1
ppp authentication chap
ppp multilink
ppp multilink fragment-delay 200
ppp multilink interleave
You've right dialer-list, username/pwd, hostanme settings (for CHAP) settings? Did you observe when the fr circuit goes down dialer is trying or not?
OR instead of backup did you try to use dialer interface as primary?
The problem has nothing to do with the configuration. The same configuration worked fine with the previous ios. With the ios upgrade, the dialer is not triggered to place a call(interesting traffic is met, but dialer does not place a call)
Looks like CSCeb39295, you can try using bri interface instead of dialer interface or try with a sw upgrade.
Hope this helps.
102
