Webcast-Catalyst9k
Dial backup problem
We have two 1700 routers and leased line connection,and we want to make a back up our primary connection with us robotics dial modems,we had a configuration bottom on this sheet.what was wrong in our configuration?when we make down primary link,dial in progress never dial after this?what we should do
1 REPLY
Re: Dial backup problem
configuration;
Building configuration...
[OK]
santral_perpa#sh run
Current configuration : 1622 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname santral_perpa
ip subnet-zero
modemcap entry MY_USR_MODEM:MSC=&f1s0;=1
modemcap entry USR_SPORTSTER:MSC=&f1s0;=1
voice call carrier capacity active
no voice hpi capture buffer
no voice hpi capture destination
fax interface-type fax-mail
mta receive maximum-recipients 0
interface Loopback0
ip address 192.168.2.20 255.255.255.0
interface FastEthernet0/0
ip address 192.168.1.20 255.255.255.0
speed auto
interface Serial0/0
mtu 512
bandwidth 256
ip address 10.0.0.20 255.255.255.0
no ip mroute-cache
no fair-queue
interface Async5
no ip address
encapsulation ppp
dialer in-band
async default routing
async mode dedicated
no peer default ip address
fair-queue
ip classless
ip route 192.168.0.0 255.255.255.0 10.0.0.10
no ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
call rsvp-sync
voice-port 1/0
timeouts ringing 30
timeouts wait-release 3
voice-port 1/1
timeouts ringing 30
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 2
port 1/0
dial-peer voice 2 pots
port 1/1
dial-peer voice 3 voip
destination-pattern 1
session target ipv4:10.0.0.10
ip qos dscp cs5 media
line con 0
password
login
line aux 0
modem InOut
modem autoconfigure type usr_sportster
transport input all
stopbits 1
speed 1200
flowcontrol hardware
line vty 0 4
password
login
no scheduler allocate
end
santral_perpa#sh diag
Slot 0:
C1760 1FE VE 4SLOT DV Mainboard Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 3.0
PCB Serial Number : FOC07230S34
Part Number : 73-7167-03
Board Revision : A0
Fab Version : 04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 16 41 03 00 C1 8B 46 4F 43 30 37 32
0x10: 33 30 53 33 34 82 49 1B FF 03 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Packet Voice DSP Module Slot 0:
Hardware Revision : 3.2
Part Number : 73-6726-01
Board Revision : A0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : ICP07200VSM
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 02
Number of DSP's : 1
DSP memory size(in kwords): 256
Type of DSP : TMS320C549
0x00: 04 FF 40 02 AC 41 03 02 82 49 1A 46 01 42 41 30
0x10: 80 00 00 00 00 02 03 C1 8B 49 43 50 30 37 32 30
0x20: 30 56 53 4D 03 00 81 00 00 00 00 04 00 09 02 FF
Packet Voice DSP Module Slot 1:
Not populated
WIC/VIC Slot 0:
Serial 1T
Hardware revision 1.0 Board revision M0
Serial number 0030560676 Part number 800-01514-01
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 02 01 00 01 D2 51 A4 50 05 EA 01 00 00 00 00
0x30: B0 00 00 00 03 05 04 01 FF FF FF FF FF FF FF FF
WIC/VIC Slot 1:
Dual FXS Voice Interface Card
Hardware revision 1.1 Board revision B0
Serial number 0030240834 Part number 800-02493-04
0x20: 01 0E 01 01 01 CD 70 42 50 09 BD 04 00 00 00 00
0x30: 58 00 00 00 03 03 20 01 FF FF FF FF FF FF FF FF
santral_perpa#sh int async 5
Async5 is up (spoofing), line protocol is up (spoofing)
Hardware is Async Serial
MTU 1500 bytes, BW 2 Kbit, DLY 100000 usec,
Encapsulation PPP, LCP Closed
Closed: IPCP, loopback not set
DTR is pulsed for 5 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:59:14
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
--More--
santral_perpa#sh line aux 0
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 5 AUX 300/300 - inout - - - 0 0 0/0 -
Line 5, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 300/300, no parity, 1 stopbits, 8 databits
Status: Ready, Active, CTS Raised, Modem Configuring, Modem Speed Locked
Autoconfig Running
Capabilities: Hardware Flowcontrol In, Hardware Flowcontrol Out
Modem Callout, Modem RI is CD, Line is permanent async interface
Modem Autoconfigure
Modem state: Ready
Modem hardware state: CTS* noDSR DTR RTS
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 never none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is usr_sportster.
Session limit is not set.
Time since activation: never
Editing is enabled.
History is enabled, history size is 10.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are pad udptn telnet rlogin.
Allowed output transports are pad telnet rlogin.
Preferred transport is telnet.
No output characters are padded
hostname santral_karakoy
ip subnet-zero
chat-script dialout abort error abort busy "" ""at"ok"atdt \t" timeout 45 connec
t \c
interface Loopback0
ip address 192.167.0.10 255.255.255.0
ip address 192.168.0.10 255.255.255.0
speed auto
interface Serial0/0
mtu 512
bandwidth 256
backup delay 0 10
backup interface Async5
ip address 10.0.0.10 255.255.255.0
no ip mroute-cache
no fair-queue
interface Async5
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer string 92103747
dialer hold-queue 10
dialer-group 1
no fair-queue
ip classless
ip route 192.168.1.0 255.255.255.0 10.0.0.20
no ip http server
ip pim bidir-enable
snmp-server engineID local 00000009020000505008F6C0
call rsvp-sync
voice-port 1/0
timeouts call-disconnect 1
timeouts ringing 30
voice-port 1/1
timeouts ringing 30
port 1/0
port 1/1
session target ipv4:10.0.0.20
line con 0
password
login
line aux 0
modem InOut
transport input all
autoselect ppp
stopbits 1
line vty 0 4
password
login
end
86
