Dial-in with V.110 Protokoll on 3725 + NM-30DM Modul
i will dial-in with protokoll V.110, but when i use "sh modem config 2/0" then:
S29 = 6 V.90 modem standard
I will change it to:
S29 = 8 V.110.
How can i do that!!!
I will work with this Protokoll on this Router only.
VIP Purple
Re: Dial-in with V.110 Protokoll on 3725 + NM-30DM Modul
which IOS version are you using ? You need at least 12.2(8)T, I think the 3725 ships with 12.2(3), so you would need to upgrade.
Georg Pauwen
OK, check it up.....
Question:
Can i flash the digital-Moduls (Firmwareupgrade)?
Is it nessesary?
If i want use the string "modemcap" and wand save the configuration then shows follow error:
"This command has no effect on this line; use modem AT commands instead"
Is it an Bug?
Frank
OK,
i did dial-in in my company and was on the router of our costumer.
Here details......
bvrr02#dir
Directory of flash:/
1 -rw- 7507936 Mar 01 1993 00:06:38
c3725-i-mz.122-13.T8.bin
2 -rw- 16773120 Mar 01 1993 04:19:16
c3725-is-mz.122-13.T8.bin
31932416 bytes total (12713984 bytes free)
bvrr02#
Defautl IOS is "c3725-i-mz.122-13.T8.bin"
later i did try flash the IOS
"c3725-is-mz.122-13.T8.bin"
For me is it not the first time to flash cisco routers, but when i use the command "sh ver", then i see the old IOS. When is use the command "sh ru". Then i see the new IOS. What is wrong?
I did change config-register from 0x2102 to 0x2101 then i download the new IOS. Then change it the boot system flash to the new IOS (boot system flash c3725-is-mz.122-13.T8.bin) and change to 0x2102 and made a reboot. That`s all. Was the new IOS not correctly download. I did need around 3 times to download the IOS on this router, because the have in our company many switch and V-LAN`s. My Workstation was the TFTP-Server and work with the virtual Networkdriver on one NIC and simulate two NIC`s then.
OK, i think i will delete the new IOS and try a new download from the website and then in the router.....
What it work:
I can dial-in with default setting on a client. PPP over ISDN ect.....
If i wand dial-in with V.110 setting on a client, i can`t dial in and get an error on a client. "no open Ports....."
The client is a Notebook with whe ISDN-Card. Here can i use AT-commands an change to V.110. Ohter way is to use my mobilphone with V.110 Protocoll. I can dial-in on ISDN-Cards with my Mobilphone, but not on this router.....
Help me, please.
VIP Purple
do you have at least portware 2.7.4.0 ? If you can, upgrade to 2.9.4.0.
Check what you see when you issue the command show modemcap x (whereby x is your digital modem). It probably says S29=6. Can you change that to S29=8 with the edit modemcap x command (in config mode) ?
Georg
I can`t connect via V.110
Can you help me, please.
General OS:
Modem control/process activation debugging is on
Dial on demand:
Dial on demand events debugging is on
CSM Modem Management:
Modem Management Call Switching Module debugging is on
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn q931 is ON.
xxx2#
*Mar 13 15:35:27.572: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0072
Sending Complete
Bearer Capability i = 0x8890214840BB
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x21, 0x83, 'xxxxxxxxx'
Plan:ISDN, Type:National
Low Layer Compat i = 0x8890, '!H@', 0xBB
*Mar 13 15:35:27.576: CSM: MODEM_REPORT from 1/0:0, call_id=0x14, event=0x1, cause=0x0, dchan_idb=0x6194F328
*Mar 13 15:35:27.576: CSM: Next free modem = 2/0; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/0 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/1; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/1 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/2; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/2 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/3; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/3 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/4; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/4 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/5; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/5 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/6; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/6 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/7; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/7 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/8; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/8 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/9; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/9 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/10; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/10 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/11; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/11 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/12; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/12 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/13; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/13 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/14; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/14 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/15; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/15 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/16; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/16 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/17; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/17 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/18; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/18 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/19; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/19 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/20; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/20 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/21; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/21 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/22; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/22 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/23; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/23 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/24; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/24 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/25; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/25 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/26; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/26 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/27; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/27 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/28; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/28 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM: Next free modem = 2/29; statbits = 10040
*Mar 13 15:35:27.576: Modem 2/29 CSM: TTY statbits = 10040
*Mar 13 15:35:27.576: CSM incall failed with dchan index=1, idb state=4, sb=0
*Mar 13 15:35:27.576: CSM: MODEM_REPORT rcvd DEV_INCALL for call_id 0x14, No modem available
*Mar 13 15:35:27.576: ISDN Se1/0:15 **ERROR**: accept_incoming_csm_call: modem problem Requested circuit/channel not available(0x2C): b channel 0, call id 0x14
*Mar 13 15:35:27.576: CSM: MODEM_REPORT from 1/0:0, call_id=0x14, event=0x0, cause=0x0, dchan_idb=0x6194F328
*Mar 13 15:35:27.576: CSM: MODEM_REPORT rcvd DEV_IDLE for call_id 0x14, modem not found due to wrong b channel number or b channel is deallocated
*Mar 13 15:35:27.580: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8072
bvrr02#
*Mar 13 15:35:27.580: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8072
Cause i = 0x80AC - Requested circuit/channel not available
*Mar 13 15:35:27.780: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0072
*Mar 13 15:35:27.780: CSM: MODEM_REPORT from 1/0:0, call_id=0x14, event=0x0, cause=0x0, dchan_idb=0x6194F328
*Mar 13 15:35:27.780: CSM: MODEM_REPORT rcvd DEV_IDLE for call_id 0x14, modem not found due to wrong b channel number or b channel is deallocated
*Mar 13 15:35:27.780: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8072
bvrr02#
version 12.2
no service dhcp
hostname xxxxx
boot system flash
boot system flash c3725-i-mz.123-5.bin
enable password xxxxxxxxx
username xxxxxxxxx password 0 xxxxxxxx
modem country mica germany
ip subnet-zero
no ip domain lookup
isdn switch-type primary-net5
modemcap entry new:MSC=&F&D2S34=9600S29=8
controller E1 1/0
pri-group timeslots 1-31
description "SMS-Dialin der Fahrzeuge"
interface Loopback0
ip address 172.22.20.1 255.255.255.0
interface Loopback1
ip address 172.22.61.1 255.255.255.0
interface FastEthernet0/0
description "LAN - BVR Duesseldorf"
ip address 192.168.41.16 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation ppp
dialer rotary-group 10
dialer-group 5
isdn incoming-voice data
no cdp enable
ppp authentication chap
ppp multilink
interface Group-Async0
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer idle-timeout 900
dialer-group 5
async mode interactive
peer default ip address pool ASYNC
no keepalive
no fair-queue
ppp multilink
group-range 65 94
interface Dialer10
ip unnumbered Loopback1
encapsulation ppp
dialer in-band
dialer-group 5
peer default ip address pool ISDN
ppp multilink
ip local pool ASYNC 172.22.60.2 172.22.60.254
ip local pool ISDN 172.22.61.2 172.22.61.254
ip classless
ip route 172.29.199.0 255.255.255.0 192.168.41.210
ip route 193.73.132.0 255.255.255.0 192.168.41.210
ip http server
line con 0
line 65 94
flush-at-activation
modem autoconfigure type new
terminal-type m
line aux 0
line vty 0 4
exec-timeout 0 0
password xxxxxxx
logging synchronous
login
end
167
