Dial-inPCs from many diff. places
we want to use a Cisco 801 as access-server to allow one company to dial-in to our network. Because the dial-in should be done from many different locations by PC or Notebook, a mapping can not be done.
The router is configured with dialer-profiles to provide connections to 4 locations.
When a PC dials in, no connection will be established. Debug shows the following output: Incomming call rejected, unbindable.
interface Dialer 5
ip address ...
no ip split-horizon
encapsulation ppp
dialer in-band
dialer idle-timeout 120
dialer remote-name pc
dialer-group 1
dialer pool 5
ppp authentication chap callin
ppp multilink
no cdp enable
peer default ip address pool isdn-Group-5
Can anyone help?
Bernd
  • Other Network Infrastructure Subjects
Re: Dial-inPCs from many diff. places
Try this...
1.
interface Dialer1
description MY 801 router's dialer
ip unnumbered Loopback0
no ip directed-broadcast
encapsulation ppp
no ip route-cache
no ip mroute-cache
no keepalive
dialer in-band
dialer idle-timeout 600
dialer-group 8
peer default ip address pool ISDN-POOL
no cdp enable
ppp multilink
2. Make sure your isdn-Group-5 pool is defined - I don't see it.
3. Where is the username statement ? How the user authenticates ?
Let me know the result.
Best,
Plamen
make sure you debug ppp authentication as well.. it`ll make it easy to see a client problem like not using chap etc`
Thank you very much!
I have solved the problem by using a dialer-map configuration.
Bernd
Looks like you are missing the " dialer remote-name" command that helps the router bind the dialer interface to the correct remote router (we use multiple dialers on one ISDN line).
90
