Dial-On-Demand Routing on 827 with PPPoA
Hello everyone, first post on the forums and quite new to cisco world. :)
Please forgive my english, it is not my native language. :)
Now my question, i have a 827 with a pppoa dsl line. My provider charges me for the time connection stays up, so i would configure my router to work in dial-on-demand routing. I'have read many threads and many pages here on the cisco website and made a long search on google finding a sort of configuration (see attached) that (according to me!) could be working but it doesn't. All the traffic is considered interesting and the oly counter i can make to work is "ppp timeout idle".
Tks in advance to everyone could help.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 827
enable secret xxxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
no ip domain-lookup
ip dhcp excluded-address x.x.x.1 10.0.0.3
ip dhcp pool lan
network x.x.x.0 255.0.0.0
default-router x.0.0.1
dns-server x.x.x.100 195.210.92.100
interface Ethernet0
ip address x.x.x.1 255.0.0.0
ip nat inside
no cdp enable
hold-queue 4096 in
hold-queue 4096 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Dialer0
bandwidth 640
ip address negotiated
ip idle-group 101 out #doesn'twork
ip nat outside
encapsulation ppp
dialer pool 1 #dialer idle timeout is not considered in "sh caller timeouts"
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname ****
ppp chap password 0 ****
ppp pap sent-username **** password 0 ****
ppp timeout idle 30 inbound
ip nat inside source list 100 interface Dialer0 overload
ip nat inside source static tcp 10.0.0.3 4662 interface Dialer0 4662
ip nat inside source static udp 10.0.0.3 4662 interface Dialer0 4662
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 100 permit ip 10.0.0.0 0.255.255.255 any
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq ftp
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq pop3
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq smtp
access-list 101 permit tcp 10.0.0.0 0.255.255.255 any eq www
access-list 101 deny tcp any any eq domain
dialer-list 1 protocol ip list 101
dialer-list 2 protocol ip deny #even with this all traffic is interesting
no cdp run
line con 0
stopbits 1
line vty 0 4
password ****
login
scheduler max-task-time 5000
end
Bronze
Re: Dial-On-Demand Routing on 827 with PPPoA
are you saying that even with dialer-group 2 defined on Dialer0, the connection still stays open after 2 minutes of idle time?
I would suggest to do a "debug dialer packets" to see which packets are keeping the connection open exactly.
BTW, I think you would also need to permit udp domain packets in your list 101, or your dns requests will not push open the line.
hth
Herbert
Hi Herbert, tks for your reply.
I have already done a debug on dialer packets and have discovered that before making connection, interesting traffic is based on internal lan addresses, once the connection is up and the dialer has is own ip address, interesting traffic is based on this one. I've already changed my dialer list to work even with the external address but now it seems there is no dialer idle timeout even if the command is properly configured.
When ia type a "sh caller timeouts" i see no timers.
Another thing i have observed is that typing a "sh dialer" i can't see any active connections when line and protocols are up.
It seems that when dialer makes the call it passes all the work to a virtual access interface that is not configurable nor is based on dialer's settings.
i'm sorry if this sounds obvious to you but this is the first time i work with those routers and some things are not so obvious to me. :)
Bye.
126
