dial-on-demand with 4 bri problem
I have a problem with a Cisco 2610Xm + 4 bri router that call another Cisco 2610Xm + 4 bri router.
I have configured the caller with a dialer profile and 4 different dialer strings, then I've added the "dialer order" parameter with the round-robin option (the problem is similar with other options too).
The problem is: the router calls using only two dieler strins and not four... looking at "show isdn history" the router try continuously to call only two numbers ignoring the others...
this is a sh run:
version 12.2
service password-encryption
hostname CALLER
enable password 7 ...
username CALLED password 7 ...
ip subnet-zero
no ip domain lookup
isdn switch-type basic-net3
interface FastEthernet0/0
ip address 10.X.Y.Z 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface BRI1/0
no ip address
encapsulation ppp
dialer pool-member 1
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
interface BRI1/1
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface BRI1/2
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface BRI1/3
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface Dialer1
ip address negotiated
encapsulation ppp
load-interval 30
dialer pool 1
dialer remote-name CALLED
dialer order round-robin
dialer idle-timeout 600
dialer string 0...1
dialer string 0...2
dialer string 0...3
dialer string 0...4
dialer load-threshold 1 either
dialer-group 1
no cdp enable
ppp multilink
ip classless
ip route 10.A.B.0 255.255.255.0 Dialer1
no ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
password 7 ...
login
end
VIP Purple
Re: dial-on-demand with 4 bri problem
I have a feeling that this might be related to the ppp multilink feature you have configured, in combination with the dialer load-threshold setting of 1. Can you try and take the multilink setting out, or increase the dialer load-threshold to something higher, like 127 ? Also, can you post the output of debug dialer ?
GP
I've tried to set no multilink but the problem wasn't solved. Now I've increased the load-threshold but it doesn't seem to work...
the output of "debug dialer" is:
*Mar 3 22:30:35.910: BRI1/0: wait for isdn carrier timeout, call id=0x9BE8
*Mar 3 22:30:50.999: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 68 changed to down
*Mar 3 22:30:59.052: BR1/0 DDR: rotor dialout [priority]
*Mar 3 22:30:59.052: BR1/0 DDR: Attempting to dial NUMBER1
*Mar 3 22:30:59.316: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 69 changed to up
*Mar 3 22:31:01.272: BRI1/0: wait for isdn carrier timeout, call id=0x9BE9
*Mar 3 22:31:04.273: BR1/0 DDR: rotor dialout [priority]
*Mar 3 22:31:04.273: BR1/0 DDR: Dialing cause ISDN fast roll-over
*Mar 3 22:31:04.273: BR1/0 DDR: Attempting to dial NUMBER2
*Mar 3 22:31:06.232: BRI1/0: wait for isdn carrier timeout, call id=0x9BEA
*Mar 3 22:31:21.300: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 69 changed to down
*Mar 3 22:31:29.101: BR1/0 DDR: rotor dialout [priority]
*Mar 3 22:31:29.101: BR1/0 DDR: Attempting to dial NUMBER1
*Mar 3 22:31:29.374: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 70 changed to up
*Mar 3 22:31:31.593: BRI1/0: wait for isdn carrier timeout, call id=0x9BEB
*Mar 3 22:31:34.594: BR1/0 DDR: rotor dialout [priority]
*Mar 3 22:31:34.594: BR1/0 DDR: Dialing cause ISDN fast roll-over
*Mar 3 22:31:34.594: BR1/0 DDR: Attempting to dial NUMBER2
*Mar 3 22:31:36.578: BRI1/0: wait for isdn carrier timeout, call id=0x9BEC
*Mar 3 22:31:51.694: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 70 changed to down
*Mar 3 22:31:59.151: BR1/0 DDR: rotor dialout [priority]
*Mar 3 22:31:59.151: BR1/0 DDR: Attempting to dial NUMBER1
*Mar 3 22:31:59.395: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 71 changed to up
Someone had already configured one Cisco with a 4 bri module to call another Cisco with 4 bri module? Can you give me a sample configuration? Thanks a lot! Happy new year
problem solved by IOS upgrade.
187
