Webcast-Catalyst9k
Dial order in rotary group
We're using the following dialer and have 4 BRIs in a rotary group.
Every time the dialer tries to set up a new channel, it starts with the first dialer map entry, finds that the line is busy, waits for 30 sec and tries the next number. This process is repeated until it finds an available channel.
It has trouble setting up the 7th and 8th channels, the channel is set up but is idle for 20 sec, then disconnected quoting "normal call clearing". (20 sec is the fast-idle-timeout.)
Any obvious mistakes ?
interface Dialer1
ip address 192.168.153.1 255.255.255.0
encapsulation ppp
no ip route-cache
no ip split-horizon
no ip mroute-cache
load-interval 30
dialer in-band
dialer idle-timeout 1800
dialer map ip 192.168.153.2 name marie138 2002
dialer map ip 192.168.153.2 name marie138 2003
dialer map ip 192.168.153.2 name marie138 2004
dialer map ip 192.168.153.2 name marie138 2005
dialer load-threshold 25 either
dialer-group 1
Re: Dial order in rotary group
Now since you have idle-timeout configured for 1800 secs, a channel should stay connected for atleast 30 mins..But not sure why "ppp multilink" is not configured which you need it under all the bri interfaces and dialer interface too. With that receiving router will bind all the calls to the same bundle on the receiving side..
Now in order to know why the channel is getting disconnected, we need to know following debug for a call getting disconnected early..
debug dialer
debug ppp nego
debug ppp authentication
debug isdn q931
term mon
Also full running config will help..
For more information on "fast idle timer" pl. refer to following url
http://www.cisco.com/univercd/cc/td/doc/product/software/ios11/arbook/arddr.htm#xtocid2225311
Hi.
Thanks for your reply. As you have pointed out some of the config was missing in the question. "ppp multilink" was configured.
Using dialer redial interva 5 attempts 3 and setting the wait-for-carrier-time to a low value seems to have sorted this problem.
I do have another question, though. We have four ISDN lines, using all 8 B-channels for data. The first channel to be set up is BRI 1/3:2, followed by BRI 1/3:1, BRI 1/2:2, BRI 1/2:1 and so on until all 8 are set up if the load is large enough.
I find that if a line is down but not shut down, for instance physically disconnected, the router keeps trying to connect using that line.
I would like the router to skip this interface and go to the next one, but can't seem to find the right command to do that. Grateful for any hints.
Hans Petter Helsor
100
