Dial out and dialin over the same BRI port of a Cisco Router
Hi anyone please check for me the following config if I want to enable dial out and dial in on a BRI port of the 1720 router.
interface BRI0
! Dial out
ip address 10.10.68.3 255.255.255.0
encapsulation ppp
dialer idel-timeout 60
dialer map ip 10.10.68.1 name KajangRtr broadcast 87321624
dialer load-threshold 80 either
dialer-group 1
isdn switch-type basic-net3
ppp authentication chap
ppp multilink
dialer rotary-group 1
!Dial in
interface dialer1
ip unnumbered Bri0
encapsulation ppp
dialer-group 1
ppp authentication chap callin
ppp multilink
dialer-list 1 protocol ip permit
Please help to verify my above config for the dial out and dial in portions.
Thank you.
1 REPLY
Silver
Re: Dial out and dialin over the same BRI port of a Cisco Router
You will find it much easier to accomplish what you want if you use dialer profiles rather than legacy dialer maps. See, for example, //www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/dialts_c/dtsprt6/dcdbakdp.htm. Note that this example does not do dial out and dial in, but it does show you what is meant by a "dialer profile" which is the important concept. Dial in versus dial out is then trivial to configure, just define each in its own dialer.
Good luck and have fun!
Vincent C Jones
www.networkingunlimited.com
76
