Community Member
Dial-up access problem
I want to access router by dial-up, via ppp.
The configuration of router is ...
x25 routing
x29 profile x25-fr 1:0 2:0 3:2 4:1 5:0 6:0 7:21 8:0 9:0 10:0 11:14
interface Ethernet0
description <internet access>
ip address
no ip mroute-cache
no ip route-cache
media-type 10BaseT
interface Serial0
no ip address
no ip mroute-cache
encapsulation x25
no ip route-cache
bandwidth 1544
x25 address 1212501
x25 htc 100
x25 facility windowsize 4 4
x25 facility packetsize 512 512
x25 facility throughput 48000 48000
ip local pool pu_singenta
translate x25 12125010754 profile x25-fr ppp ip-pool scope-name pu_singenta routing
The problem is...
I tried to connect to router by dial-up, but it's failed. so i tested as following.
When i use a PC using OS/WIN98, then it is ok.
When is use a PC using OS/WIN2000, then it is failed.but if i changed the IP-address( of IP-POOL(pu_singenta) into anything else except
"", then it is ok.
As a result, in WIN98, all is ok, but in WIN2000, i can not use IP address ,"", as a pool IP.
I must use IP address, "".
Would you help me.
Community Member
Re: Dial-up access problem
If it is working under 98, then there must have been some sort of a change in the 2000 kernel, drivers, stack, something. Give Microsoft a shout, as this is not a known issue.
