Webcast-Catalyst9k
Dial Up connection PRI to BRI and BRI to PRI (Both Way)
Hi All,
I will appreciate if someone can share his experiences about the dialup connection. I have E1/PRI in central site and BRI's in remote sites.. Both site, central and remote, can dial and accept dial from central or remote site. So it's not like a "legacy dial up central to remote site".. If it's possible, can you give the sample config or the url in the cisco web site...
many thanks
regards
Re: Dial Up connection PRI to BRI and BRI to PRI (Both Way)
Hi There, try http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt4/dcdchant.htm if you're not succesfull, drop me an email.
Good Luck !!
J.
hi there,
many thanks to you
I try, I will let you knwo the result....
regards
167
