Dial-up ISDN Routing Question
Hello Once Again.
I'm wondering if this will work.
On my 1720 I have a Dial-up ISDN line configured as a DDR backup for my Serial line (See Previous Post).
All works well when I take the serial line down, the ISDN dials up the ISP and connects. I can ping out from the router to addresses on the Internet but packets from the Fast Ethernet interface do not go out.
Running a "ip route command" at the router I see that the "gateway of last resort" (0.0.0.0 .0.0.0.0) is connected to "Dialer0" but a trace route from a machine on my LAN shows that packets stop at the Fast Ethernet interface on the router.
So after that long intro here's my question.
Will ISP's allow traffic out on their networks which is not from an IP address on their network? The obvious answer is no, I think. The network for the Fast Ethernet is 1.1.1.1 x.x.x.x but the network for the ISDN interface is 2.2.2.2 y.y.y.y
Why can't I route packets through do the Dialer0 int?
Thanks for reading this
Greg
Re: Dial-up ISDN Routing Question
Mostly, when you dial up to an ISP you have to use on the BRI.
First verify that you can send packets over the ISDN line.
Routing from an IP segment 1.x.x.x towards the Internet will normally require NAT. Do you have on your int s0/0?
If this is the case, you will need it on your ISDN as well.
Last but not least, you need to know how your ISP handles your traffic and setup your router accordingly.
Thanks for the response. I can get out over the ISDN line from the router. Here is my running config.
I did not know if the 1720 series supportted NAT.
Greg
Current configuration:
version 12.0
service timestamps lo
hostname Metro_1720
enable secret 5 $1$t.o8$PgF2G3LT/Kx.PlXjf/p4g/
username Metro2 password 0
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-5ess
isdn voice-call-failure 0
interface Serial0
description 768K line to Frontier_AZ
backup delay 10 30
backup interface Dialer0
ip address 64.211.1.86 255.255.255.252
no ip directed-broadcast
service-module t1 timeslots 1-12
service-module t1 remote-alarm-enable
interface BRI0
description ISDN backup to Frontier_ROC
no ip address
encapsulation ppp
dialer rotary-group 0
no fair-queue
no cdp enable
interface FastEthernet0
description connected to EthernetLAN
ip address 64.211.20.65 255.255.255.224
full-duplex
interface Dialer0
description Dailer for ISDN to Frontier_ROC
ip address negotiated
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 300
dialer string 7774660
dialer hold-queue 10
dialer load-threshold 200 outbound
dialer-group 1
no fair-queue
no cdp enable
ppp authentication pap chap callin
ppp chap hostname Metro2
ppp chap password 7 0215094E5E051D2C
ppp pap sent-username Metro2 password 7 0215094E5E051D2C
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Dialer0 250
no ip http server
access-list 101 permit ip any any
access-list 101 permit icmp any any
dialer-list 1 protocol ip permit
snmp-server engineID local 0000000902000002B9CC0B70
snmp-server community public RO
snmp-server location 205 LaGrange Ave
snmp-server contact Greg Young,(716) 254-2988 x238,GYoung@Metrocircuits.com
line con 0
exec-timeout 0 0
password
login
transport input none
line aux 0
line vty 0 1
password
login
line vty 2 4
password
login
end
I suppose you are using private addressing for the workstations on LAN. YOu should be using NAT on the router, to connect to the internet. Your BRI port is getting an IP add from the ISP, which is a public IP and thats the reason why you can reach the internet.
Thanks for responding.
Yes we are using Private IP Addresses on the LAN via Novell BorderManager which is before the router on the LAN side. To be honest I'd rather not change that.
So now I need to figure out how to enable NAT for the BRI0/Dialer0 and FastEthernet0 configuration but still be able to keep my static IP Address on the FastEthernet int so things work for routing to the Serial0 int.
Sheeeeeeeesh
Greg
198
