Dialer pool-member max-link min-link issue
What will happen with the incoming and outgoing calls when I configure the following:
Case 1:
interface BRI0
encapsulation ppp
dialer pool-member 10 min-link 1 max-link 1
interface Dialer10
encapsulation ppp
dialer pool 10
Outgoing calls:
By min-link 1 command I will be able to bring up one B channel.
Incoming call:
I won’t be able to call in because one B channel has already reserved for the outgoing call.
I would like to know that whether this assumption is true or not.
Case 2:
How can I reserve one B channels for each Dialer in Router1 and how can I provide two B channels also for Dialer10 or Dialer20 if needed? Is this configuration good?
Router1
interface BRI0
encapsulation ppp
dialer pool-member 10 min-link 1 max-link 2
dialer pool-member 20 min-link 1 max-link 2
interface Dialer10
encapsulation ppp
dialer pool 10
interface Dialer20
encapsulation ppp
dialer pool 20
Router2
interface BRI0
encapsulation ppp
dialer pool-member 1 max-link 2
dialer pool-member 2 max-link 2
interface Dialer1
encapsulation ppp
dialer pool 1
interface Dialer2
encapsulation ppp
dialer pool 2
Re: Dialer pool-member max-link min-link issue
Case 1: Your assumption is not correct. Min-link is to reserve number of links for outbound call. So if you have min and max link set to 1 that means only one inbound call will be accepted by that pool members.
Case 2: Router 1: min 1 and max 2, means minumum 1 link is reserved for outbound call so alleast one inbound call will be accepted. But it can have max 2 outbound calls too from pool members.
Case 2: Router 2: If only max-link is used (without min link), it is for either direction.. So pool members can receive and place 2 calls from that interface.
You can use "dialer max-link" command under the dialer interface (dialer profile) to control the links from the users rather then spredding the links on pool members. Thats a good way.
Case 1: I’m a little confused. I really don’t understand why I have only one incoming call in both cases if I have ‘min1 max 1’ as well as ‘min 1 max 2’ configured. Would appreciate it if you can explain me how the min-link and max-link works?
Case 2: If I understood you correctly in 'BRI' environment in order to provide one B channel always for both Dialers I have to control the reservation on the pool level. However if would like to prevent the over utilization I have to control it on Dialer interface level.
Router1
interface BRI0
encapsulation ppp
interface Dialer10
encapsulation ppp
dialer pool 10
dialer max-link 2
interface Dialer20
encapsulation ppp
dialer pool 20
dialer max-link 2
Case 3: In PRI environment the aim is to provide as many B channels for one Dialer (Customer) as we want no more and no less. So if I would like to create two backup links one with 128K and one with 256K I have to do the following:
Interface s3/0:15
encapsulation ppp
dialer pool-member 10 min-link 2
dialer pool-member 20 min-link 4
interface Dialer10
description *** 128K backup to Customer1 ***
encapsulation ppp
dialer pool 10
dialer max-link 2
interface Dialer20
description *** 256K backup to Customer2 ***
encapsulation ppp
dialer pool 20
dialer max-link 4
I want to prevent the over utilization.
Is this configuration correct?
250
