09-03-2003 02:19 AM - edited 03-02-2019 10:03 AM
I have a 2520 configured with 2 dialer interfaces. Dialer3 is configured for a dial up to a remote site, and dialer4 is configured for dial in. The problem is that when I add dialer3 to the dialer pool, dialer 4 doesnt work. Instead I get a debug that the call is rejected because the interface cant bind. If I remove dialer3, dialer4 works fine. Is there a better way to do this, or is my config incorrect?
interface BRI0
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool-member 1
dialer pool-member 2
isdn switch-type basic-net3
no fair-queue
no cdp enable
interface Dialer3
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 30
dialer string 01xxxxxxx
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp chap hostname xxxxxx
ppp chap password 7 xxxxxxxxxxxx
interface Dialer4
description ISDN dialin
ip unnumbered Ethernet0
ip nat inside
encapsulation ppp
dialer pool 2
dialer-group 2
peer default ip address dhcp
fair-queue
no cdp enable
ppp authentication chap pap callin
Wayne
09-03-2003 02:28 AM
Hi Wayne,
Do you really need 2 pools?
For a basic config, you could remove the dailer pool-member 2 from the BRI and add Dialer4 to pool 1.
Not sure if that will solve your problem though.
hth
Herbert
09-03-2003 02:53 AM
Hi Herbert
I have tried to use a single dialer pool; I get the same results. Could it be a bug in the IOS?
09-05-2003 06:14 AM
Wayne,
You need to configure PPP authentication on the BRI interface itself. The authentication is needed in order for the dialer interface binding to occur.
Mark
09-07-2003 10:13 PM
Thanks Mark
I will give it a try tomorrow.
09-11-2003 11:40 PM
hi Herbert
i got ur logic of putting dialer 4 also in dialer pool 1.
can u pls tell me then whts the exact reason for putting a dialer interface in different dialer pool ?
prem
09-17-2003 10:43 PM
Hi prem,
you can use different dialer pools when you have multiple physical interfaces, and you want to reserve (or prioritize) some of the interfaces for a specific use.
For example, if you have 8 BRI's that are used for dialin and dialout, but you want 1 BRI to be available for dialout at all times; in this case you put 7 BRI's in pool 1 and pool 2, the last one only in pool 2. Your Dialer profile used for dialin then refers to pool 1, while your dialout Dialer refers to pool 2.
hope this clarifies it a bit,
regards
Herbert
09-28-2003 10:03 PM
What would cause the following?
*Mar 1 00:09:08: ISDN BR0:1: Incoming call rejected, unbindable
*Mar 1 00:09:15: ISDN BR0:1: Incoming call rejected, unbindable
thanks
09-29-2003 02:52 AM
In order for the remote user to be able to bind to one of the dilaer interfaces, you will need to issue "dialer remote-name" command.
You have 2 dialer interfaces at the moment, and the router doesn't know which one of the 2 profiles to bind to. Add the dialer remote-name command on both interface, and you should be able to connect.
BR,
Winnie
09-29-2003 03:15 AM
I have used the 'dialer remote-name' and still get the same binding problem.
Wayne
09-29-2003 03:30 AM
Hey Wayne,
can you get me these debugs:-
debug dialer
debug isdn q931
debug ppp neg
debug ppp auth
so we can check the call setup.
BR,
Winnie
09-29-2003 04:26 AM
also try removing on of the pool member, and just use dialer pool-memebr 1 for both dialer profile in conjunction with the dialer remote-name commands on both dialer intefaces.
09-29-2003 05:54 AM
Hello Wayne,
you have to enter
int bri0
If the phone rings, and the bri0 gets the call, there is no way to decide for the bri0 to which logical dialer interface the call should be sent.
By enabling the bri0 to read the chap username, it can decide to which logcal interface it sould connect the physical channel from bri0.
Bye
Jo
