Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
dialer pool with bri and serial interfaces.
Hi, i´m trying to configure a dialer pool using a bri interface and a serial asyn with modem interface in it. The bri and ser int accept the dial pool 1 command, but when i use the sh dialer interface dialer 1 command i can only see the ser interface as belonging to dialer pool 1, and the dialer interface never use the bri inter, even when there is an error trying to use the ser inter.
Is that posible?, can i put bri and ser interfaces in the same dialer pool and make the dialer interface to use both?.
Bronze
Re: dialer pool with bri and serial interfaces.
You should be able to place different interface types into the same dialer pool. However, by
default one will always have precedense. You could try the following, to try and understand
what is wrong.
- place only the BRI in the pool, to see if dialing successfully occurs.
- give the BRI a higher priority than the serial; it should then be used first.
Always refer to "debug dialer" when trying to figure out what is wrong; hopefully it
will give you enough info to determine the problem.
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
157
