Dialing in to a 2520 using a external modem
I have a 2520 which I am trying to configure with a external analogue US Robotics modem, to allow me to dial in and connect to my network from a dum terminal. I have the modem connected to serial 3, but each time I try to dial in the modem just ring and dose no answer.
Can anyone help.
Neil
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname test
username platn password 0 platn
ip subnet-zero
interface Ethernet0
ip address 10.0.80.1 255.255.0.0
interface Serial0
no ip address
interface Serial1
no ip address
interface BRI0
no ip address
interface Group-Async1
physical-layer async
ip unnumbered Ethernet0
encapsulation ppp
async mode interactive
peer default ip address pool modem_pool
no cdp enable
ppp authentication chap
group-range 2 3
ip local pool Modem_Pool 10.80.0.1 10.80.0.2
no ip classless
line 2 3
autoselect during-login
autoselect ppp
login local
modem InOut
transport input all
flowcontrol hardware
end
Re: Dialing in to a 2520 using a external modem
You are missing the following lines under Your line 2 3 configuration:
modem autoconfigure discovery
transport preferred none
transport output none
speed 38400
Giedrius
Anonymous
N/A
Giedrius
Thanks for you response I have added the line and I still have the same problem.
Neil
Neil
what is output of command show line 2 or show line 3 ?
You should see something similar:
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
I 114 TTY - inout - - - 1 0 0/0 -
Line 114, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Status: No Exit Banner, Modem Detected, CTS Raised
Capabilities: No Flush-at-Activation, Hardware Flowcontrol In
Hardware Flowcontrol Out, Modem Callout, Modem RI is CD,
Line usable as async interface, Hangup on Last Close,
Modem Autoconfigure, , Integrated ModemLinenumber Not Suppressed
Modem state: Idle
modem(slot/port):3/17, csm_state:IDLE_STATE,
bchan_num:-1 csm_status(0): CSM_STATUS_UNLOCKED
Group codes: 0
Modem hardware state: CTS noDSR DTR RTS
TCP/IP header compression enabled
RTP/UDP/IP header compression enabled, Modem Configured
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 never none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is mica.
Session limit is not set.
Time since activation: never
Editing is enabled.
History is enabled, history size is 10.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are lat pad v120 lapb-ta mop telnet rlogin udptn nasi.
Allowed output transports are none.
Preferred transport is none.
No output characters are padded
No special data dispatching characters
Giedrius
Anonymous
N/A
Giedrius
The output from Sh line 2 is below, I noticed that on your sh line you have Status: No Exit Banner, Modem Detected, CTS Raised where as my sh line has Status: No Exit Banner dose this indicate that the cable may be at fault ?
Neil
I 2 TTY 38400/38400 - inout - - - 0 0 0/0
Line 2, Location: "", Type: ""
Baud rate (TX/RX) is 38400/38400, no parity, 1 stopbits, 8 databits
Capabilities: Hardware Flowcontrol In, Hardware Flowcontrol Out
Modem Callout, Modem RI is CD, Line usable as async interface
Modem Discovery
Modem state: Idle
Modem hardware state: noCTS noDSR DTR RTS
^^x none - - none
never
Modem type is unknown.
Editing is enabled.
Allowed transports are none. Preferred is none.
Neil,
as You can see here,
Your modem is not detected and configured by the router, thats why it is not answering Your calls.
You either have faulty or incorrect cable, faulty modem or there is a speed mismatch between modem and Your router.
Giedrius
Anonymous
N/A
Giedrius,
Thanks for all your help.
The problem was down to a faulty cable between the modem and router.
Thanks again
Neil
119
