12-17-2002 01:59 AM - edited 03-02-2019 03:39 AM
I have a Cisco RAS with 8 Analog modems NM.
The users must use the system for dial-out, But have no knowhow regarding TCP ports ect.
How do I dial -out using a group of the analog lines, so the used ports will be automaticaly selected?
Is there a specific port that responsible for the group of all the lines?
I know that in 3Com for example you can do it by dialing to port no 6000, and the call is created by the next free interface.
thank you!
12-17-2002 10:08 AM
You can either put the lines into a rotary group ("rotary 1"), and then telnet to port 3001, or you can use Dialout software on the PC's and not worry about the port specification.
12-18-2002 12:24 AM
Do you know where can i get a free software for that?
I downloaded the one that cisco reffered me to, but it is an evaluation, and we are looking for a free tool.
12-18-2002 09:14 AM
You need to purchase it. Only evaluation copy will be free. Cisco's DialOut/EZ is now end of life so you can get it from another place as mentioned in that url.
