Diameter issue with MST
Please, is there any limit to diameter network in a network using MST (802.1s) ?
Cleber
1 REPLY
Re: Diameter issue with MST
Yes, but it's much less restrictive that what was recommended for regular STP.
Between MST regions, you are basically limited by the max-age parameter in terms of number of bridges a BPDU can go through. Inside an MST region, the parameter is max-hops. No need to be close to the limits, if you have a large diameter you can increase max-age with no real impact on convergence time.
Francois
114
