Difference between 3640 and 3640-RPS
hi ,
Can anyone tell me the basic difference betwn the 3640 and 3640-RPS router models in power supply ?
Also can I convert the 3640-RPS router to 3640 basic router by adding just the PWR-3640-AC= module to the power supply slot in the 3640-RPS router ? Will this work ????
Any inputs on the same will be of great help....
Rgds
Renzil
1 REPLY
Re: Difference between 3640 and 3640-RPS
yes, you should be able to replace the power supply and use it as a regular 3640.
Check the RPS info here :
http://www.cisco.com/univercd/cc/td/doc/product/access/rpsbk/rpshim/rps1.htm
150
