Difference between Dedicated or Interactive Async
The following example sets the mode of the interface to dedicated:
Router(config-if)#async mode dedicated
Please could any one explain me this:
Why I use a Dedicated or Interactive Mode
The following example sets the mode of the interface to interactive:
Router(config-if)#async mode interactive
The following example sets the interface to dynamic address:
Router(config-if)#async dynamic address
Re: Difference between Dedicated or Interactive Async
If you intend to run PPP over the async port between two cisco routers, you should use "async mode dedicated". If you use some PC software that requires that you interactively type you userid and password to a terminal screen before entering the PPP session then you should use "async mode interactive", which is the default.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
interactive is exec or PPP, dedicated is PPP only.
the basic difference is with interactive async interface you have the option of getting into exec mode on the router, where with a dedicated if just acts like a serial connection between the 2 networks.
129
