Webcast-Catalyst9k
Difference between LAN BAse Image and Enhanced Image
Can you tell me the difference between switches with LAN Base Image and Switches with Enhabced Image. I want to run HSRP and OSPF on two switches. Can I use LAN Base Image with this or is switches with Enhanced Image.
Many Thanks
Silver
Re: Difference between LAN BAse Image and Enhanced Image
What series of switch are we talking about?
A 2960-24TT-L and 2950-12EI.
Silver
These are layer two switches and as such will not support these L3 routing features. You will have to step up to at least a 3560 to do this.
The 2960 series does not have an Enhanced Image, just the standard software with and w/o crypto. The 2950 differences can viewed at the following link.
http://www.cisco.com/en/US/products/hw/switches/ps628/prod_bulletin09186a00800b3089.html
HTH and please rate.
950
