difference between rate-limit and policy command?
libincisco
I can not tell the difference between them except their configuration mode.
I mean in most circumstances, this two method can fit for with no difference. Am I right?
beng
Policy used to specify different classes and how the traffic will be treated in the different class. Rate-limit is just for a specific interface, no classification of the traffic.
Example:
router(conifig)#class-map CLASSNAME
router(config-cmap)#match any
router(config-cmap)# exit
router(config)#policy-map POLICYNAME
router(config-pmap)#class CLASSNAME
router(config-pmap-c)#bandwidth
if you'd like a more smooth dropping of packets you can configure WRED on this policy-map
router(config-pmap-c)#random-detect
Then apply the service policy on the interface:
Router(config-if)#service-policy [in | out] POLICYNAME
Rate-limit in CAR:
You can take a look at that technology here:
http://www.cisco.com/cpropart/sync-src/ccstcp/cc/pd/iosw/tech/carat_wp.htm
The CAR command-line syntax follows:
Rate-limit {input | output}
[ access-group [rate-limit] ]
conform-action {drop|transmit|continue|set-prec-transmit |
set-prec-continue }
exceed-action {drop|transmit|continue|set-prec-transmit |
set-prec-continue }
Where normal burst = r * 1byte/8bits * 1.5 seconds, where r is configured rate extended burst = 2 *
normal_burst
For example... to limit the outbound traffic on your ethernet0 interface to 4.5Mb. I'd go to that
interface configuration mode and type:
Router(config-if)#rate-limit output 4500000 24000 32000 conform-action transmit exceed-action drop
Hope these helps.
/beng
libincisco
I think sometimes these two methods can be exchanged, ok?
You are correct. They are different methods for doing the same thing. Policing traffic. They can be used interchangeably. Using MQC and policy/class maps allows the most options and greater flexability and is what I prefer.
thank you very much
