Difference between sh int output in 12.1(13)EA1 and 12.1(19)EA1
here I have sh int output of 12.1(13)EA1 on Cat2950:
GigabitEthernet0/1 is up, line protocol is up(connected)
Hardware is Gigabit Ethernet, address is 000b.fd08.f0f2 (bia 000b.fd08.f0f1)
MTU 1500 bytes, BW 1000000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
Link type is autonegotiation, media type is SX
output flow-control is on, input flow-control is off
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d18h
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 286000 bits/sec, 3 packets/sec
5 minute output rate 4000 bits/sec, 2 packets/sec
4577625 packets input, 2711785589 bytes, 0 no buffer
Received 1584889 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 1584209 multicast, 0 pause input
2736005 packets output, 701606101 bytes, 0 underruns
And same switch with 12.1(19)EA1:
GigabitEthernet0/1 is up, line protocol is up (connected)
Full-duplex, 1000Mb/s, link type is auto, media type is SX
Output queue: 0/40 (size/max)
5 minute input rate 108000 bits/sec, 33 packets/sec
5 minute output rate 35000 bits/sec, 24 packets/sec
43974521 packets input, 3007085736 bytes, 0 no buffer
Received 24611567 broadcasts (0 multicast)
0 watchdog, 24547025 multicast, 0 pause input
17942111 packets output, 1543226158 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
You can see difference between two outputs after "Received xyz broadcasts" in 12.1(19) is "(0 multicast)". What is meaning of this?
What is difference between this counter and multicast counter two rows under that in brackets?
Also almost 34% in first output and 56% in second of input packets are broadcast(multicasts). Can I troubleshoot source of that traffic somehow without sniffer ?
Mladen
1 REPLY
Bronze
Re: Difference between sh int output in 12.1(13)EA1 and 12.1(19)
i am not sure what the difference is. I always use the "show interface counters" and "show interface counters errors" for troubleshooting ethernet links on the 2950/3550. Its much easier then reading the show interface output.
95
