11-05-2003 05:38 AM - edited 03-02-2019 11:29 AM
I've two 7200s:
-the first was bought as a stand-alone 7200
-the second was bought with an AS5800 to be a dial shelf controller
These two 7200s are identical for memory and CPU, they are without any PAs.
I've configured these two routers to get the IOS from a TFTP server on the network.
When the first boot there aren't any problem.
When the second boot I see a "rename" of the interfaces like it is attached to an AS5800
(FastEth 0/0 is "renamed" as FastEth 0/0/0) but ONLY during the bootimage loading.
When IOS start the interface is againg FastEth 0/0.
The problem is that i can't configure the IP Address on the interface FastEth 0/0/0 for
loading the IOS because in the config (not boot) i can configure only the interface
FastEth 0/0.
I've made a sh tech-support to search difference, i found a difference
only in the Midplane EEPROM contents (look at <---):
Router OK (FA 0/0)
show c7200
Network IO Interrupt Throttling:
throttle count=0, timer count=0
active=0, configured=0
netint usec=4000, netint mask usec=200
Midplane EEPROM:
Hardware revision 2.0 Board revision B0
Serial number 21296721 Part number 73-3223-05
Test history 0x0 RMA number 00-00-00
MAC Pool Size 1024 MAC Addr Base 0050.e27c.8c00
Chassis Model 0x6
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 06 02 00 01 44 F6 51 49 0C 97 05 00 50 E2 7C <---
0x10: 8C 00 04 00 00 00 00 00 00 09 15 58 00 00 FF 00 <---
0x20: 00 00 00 00 61 1A 79 08 61 0F 00 00 60 67 1A 48 <---
0x30: 60 F9 00 00 61 1A 79 08 00 00 00 00 61 1A 79 08
Router OLD-5800 (FA 0/0/0)
show c7200
active=0, configured=1
Midplane EEPROM:
Hardware revision 2.0 Board revision A0
Serial number 18275422 Part number 73-3223-05
MAC Pool Size 1024 MAC Addr Base 0002.17e3.4800
Chassis Model 0x6
0x00: 01 06 02 00 01 16 DC 5E 49 0C 97 05 00 02 17 E3 <---
0x10: 48 00 04 00 00 00 00 00 00 05 06 50 00 00 FF 00 <---
Thanks in advance to all.
Antonio
11-11-2003 07:37 AM
I am not sure about the difference, but see if this doc helps provides you any other option :
http://www.cisco.com/en/US/products/hw/univgate/ps509/products_tech_note09186a008014f8e2.shtml
