Community Member
Difference between switch cascading, daisy chain and pt-to-pt connection
I just will like to clarify the differences between switch cascading, daisy chain and point-to-point connection. What exactly is the difference between cascade and daisy chain ? Is point-to-point connection just another term for daisy chain ?
My understanding is that with GigaStack, with cascasding configuration, you can only go up to 9 switches (with half-duplex) due to the limitation of GigaStack technology, right ?
But, if you were to configure point-to-point connection (in the daisy chain configuration), then, in theory there is no limitation, right ? But, usually, no more than 7 switches are recommended to be daisy chained due to STP performance issue, right ?
1 REPLY
Re: Difference between switch cascading, daisy chain and pt-to-p
my understanding is:
Daisy-chaining is connecting switches "in one line", i.e.:
1-2-3-4-5-6
Cascading is sometimes used for the same.
Sometimes cascading means a little more complex topology, e.g.:
1-2-3-4-5
...6......7
Switches 1 and 6 are cascaded via 2.
You can daisy-chain switches via point-to-point connections (FastEthernet, 1Gbps GBICs, GigaStack full-duplex) or by bus (GigaStack half-duplex).
Your understanding of 9 switches ans STP limits is correct.
Milan
1577
