Community Member
Difference Between Syslog Message and SNMP Trap Syslog
Anybody know the difference between Syslog messages and SNMP Trap Syslog?
Thanks.
Re: Difference Between Syslog Message and SNMP Trap Syslog
If you enable SNMP Trap Syslog the device sends a SNMP trap to your management station every time it's writing a syslog message.
I recommend disabling SNMP Trap Syslog if your Syslog is working OK.
Milan
Community Member
Thanks.
Community Member
btw with these syslog config on my catos, will i be able to receive all syslog messages including all severity level of specified facility? thanks.
#syslog
set logging console enable
set logging server enable
set logging server x.x.x.x
set logging server x.x.x.y
set logging level cdp 7 default
set logging level mcast 7 default
set logging level dtp 7 default
set logging level dvlan 7 default
set logging level earl 7 default
set logging level ip 7 default
set logging level pruning 7 default
set logging level snmp 7 default
set logging level spantree 7 default
set logging level sys 7 default
set logging level tac 7 default
set logging level tcp 7 default
set logging level telnet 7 default
set logging level tftp 7 default
set logging level vtp 7 default
set logging level kernel 7 default
set logging level filesys 7 default
set logging level pagp 7 default
set logging level mgmt 7 default
set logging level mls 7 default
set logging level protfilt 7 default
set logging level security 7 default
set logging level radius 7 default
set logging level udld 7 default
set logging level gvrp 7 default
set logging level cops 7 default
set logging level qos 7 default
set logging level acl 7 default
set logging level rsvp 7 default
set logging server facility LOCAL7
set logging server severity 4
set logging buffer 500
set logging timestamp enable
301
